Rosco »
https://forums.nicoclub.com/rosco-u15015.html
Thu Aug 17, 2006 1:30 am
I had to use a scribe (welding tool, kinda like a tiny screwdriver with a pointed tip on the end) to get the original oil filter off. I just stabbed it and did 1/4 turn everytime till it came off. I found 2 rubber oil rings on the filter when I finally got it off (hmm, maybe the reason I got a super low-mileage-brand-new-looking-SR)!! Since I swapped I have only used "hand-power" to take mine off. I don't know if people realize this or not so I will say it now. When putting your oil-filter on, tighten it to the point where it is "firm" and go 3/4 of a turn more. There is no need for it to be torqued on there to 80 gajillion ft. lbs. Also make sure when you pull the oil filter off that there is still a rubber ring on the filter so it's not attached to the block like the guy who had mine before me.
