elwesso wrote:Squee do you think you could put it somewhere else...?
While foregoing the side of this question ripe with the potential for double-entendres (...and hoping you'll edit your question to something less likely to get star billing emblazoned across someone's signature, punctuated with smileys like this: )
No, I looked at everything, and found this the least compromising safety wise, (long hoses, chafing, more movement in a hot environment = more fatigue, ETC.) and having to move things like the alarm horn, cruise control solenoid (which might turn into a major fiasco itself w/soldering and not binding the cable).
Also comes the question of positioning the filter -sideways? gasket up? down?I haven't looked with that in mind for awhile but gasket up at the backside of the drivers strut tower might have enough room (at about 10 o'clock -hood open -behind the FSTB (not a flat surface either! )). The other side on a 90 - 93 is out of the question -unless the battery gets moved. (sideways?)I hoped to put mine in with the least hassle and potential for oil pressure compromise -believe it or not.
