Oil filter relocation needed?
the_invisible
Is the SR oil filter located in a hard to reach location? Is a relocation kit needed?
I am planning on putting a Trust oil pan on my engine and I am afraid taht this oilpan will somehow block the oilfilter.
Should I get the oil filter relocation just for easy maintenance?
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
I would if it doesn't cost you to much..
the_invisible
I wouldnt mind saving $150 for unnecessary items, but if it makes life much easier, it is inevitable.
BuudWeizErr
meh, it's a pain, but it's not that hard. Go to autozone and get one of the oil filter grippers that has a ratchet adapter on it. That'll make life much easier. And be sure to lube up the filter before you put it on. It should help you when it comes time to take it off.
the_invisible
okay cool! thanks
btw, is the location hard to reach?
If it is, I wont even bother ordering it since I have the gripple already.
Spidey
Car: my car
Its a little hard to reach but not impossible. Afeter I got mine off the first time I did my oil change I got a K&N it has a hex nut on the top so it can be later removed with a socket and socket wrench. Thats what I have been doing so far.
Nils
Car: road racing
now that I have the oil filter relocation kit on I am soo glad I put it on. At first I was a little afraid, hearing horror stories about oil leaks and failing fittings. Mine has worked perfectly so far, I just pop the hood open and screw the oil filter off.. it is that easy =)
Not exactly a necessity if you are on a budget, but, if you have the extra cash it is well worth it.
n
cardinal
Which relocation kit did you use? Could you give an approximate cost?
drumma022
Enjuku Racing Link
Nils
Car: road racing
cardinal wrote:Which relocation kit did you use? Could you give an approximate cost?
Blitz oil cooler kit that comes with an oil filter relocation kit. Cant remember cost... anywhere from $500 - $800. The Blitz kit is pretty hard to get your hands on.
n
