oil filter relocation kit
apossiblehybrid
Car: 1994 Q45
i was wondering if anyone was running an oil filter relocation kit on there 94-96 q45? if so where did u get from?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I believe Superuber is.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The ones for the Z32 will work because the Z uses the same oil filter as the Q.
apossiblehybrid
Car: 1994 Q45
elwesso wrote:The ones for the Z32 will work because the Z uses the same oil filter as the Q.
awesome thanks.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Couldn't you really use any size filter as long as you keep the correct oil level. Actually it would seem like a good idea to have a larger filter and the increased lines would increase oil capacity. Am I wrong?
elwesso
2007 BMW M Coupe
if all the fittings and seal sizes were the same you could... Many oil filter relocation things actually use either canister style filter elements.
