Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Fri Feb 28, 2014 3:02 pm
Take the filter off and look at the mark left by the gasket. Does it overlay the edge of the smooth metal at all? Some
brands of filters have slightly different sized gaskets. For example, the Wix filter for the 3.5 liter gets REAL CLOSE to
the edge of the machined metal. I can see how some might go beyond it.
I'd then install a new filter, just in case there is some problem with the old filter.
How much are you tightening the filter and how? The book says 2/3 - 3/4 turn after contact, by hand. Too much or
too little can cause problems.
Are you lubricating the the gasket on the new filter prior to installing? This allows it to slide and not deform as it
is tightened. I lube the new gasket by touching it to the old gasket.
Chuck
