superJoy »
https://forums.nicoclub.com/superjoy-u42278.html
Thu Apr 02, 2009 4:46 pm
Biggest problem with Fram from my research is that you can get way better quality for less money. It's not that Fram is a particularly bad filter, just not really cost effective compared to other things on the market. Why spend more on a potentially worse design? Exactly. I think the whole "Fram made my engine blow up" mentality is a bit over-doing it imo, but what do I know. Someone very may well have lost an engine due to one. Whatever, no skin off my back. I don't run them.
I've actually been doing research about this. I really want to relocate my filter so it's really visible and get some kind of obnoxious, Nascar type monstrosity. I was thinking the Wix 51515R or something like that. It's like 5"+ tall, black, and says "RACING" on it. That would make my day.
One thing, does CA18DET use a bypass valve in the filter or in the block? I seem to remember some kind of ball/check valve in the block itself whenever I had it pulled apart. But I wasn't sure. I'm asking because I'm getting valvetrain noise on cold start. Right now I'm using a KA filter, Bosch 3400. It doesn't have a bypass. So could that be causing the noisy valvetrain? Or maybe just a crappy anti-drainback valve design that leaks. Lol
Can anyone recommend a nice, big, NASCAR looking filter that isn't junk? Fram HP1 would fit the bill, but eh, Fram. And the Wix I mentioned earlier I'd have to order, no one stocks them around me.
To the OP, what you can do is try and find 3/4"-16 thread pitch filters in similar diameter and that should work providing there's enough clearance for the added length. Also I would like someone to verify if the CA18DET needs a bypass valve in the filter itself because we kinda need to know that if we want to find an alt. filter.
