oil filter help
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
genome
Car: Altima 2.5 '03
how do i refill my transmission fluid? where does the fluid get poured into?? help please i have a 2003 altima 2.5se
Modified by genome at 4:53 PM 11/1/2005
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
check the owners manual.
nismo96ka
if i'm not mistaking the 2.5 altima's transmission is a sealed transmission. no dipstick.
suded_35L
On your car you have to drain the front diff you will see a drain plug for it on the oppsite side of the car from the oil drain plug. By draining your front diff you also drain the transmission it is all connected on the alitma just did it myself diff and transmission flush but make sure that you put the right fliud in otherwise you will screw up your diff and syncromesh.
Return to “3rd Generation Altima Sedan (2002-2006)”
