gofast24 »
https://forums.nicoclub.com/gofast24-u134326.html
Wed May 20, 2009 12:57 am
If you match exactly the thread size, gasket size, relief valve setting, and with or without anti drain back valve (if you can get that date to begin with) it would probably work. But, if you have a problem you cant go back to the filter manufacture and complain that you just fried your engine using their filter, na?After 36 years in the engine business ( in R+D and test with engine manufactures) i am sure Nissan has provided all the filter required in the size constraint allowed that your engine will ever need if you follow the recomended drain intervals.I had an incident where a filter manufacture actually recomended a filter of theirs that did not have the proper relief valve pressure setting and with the higher engine oil flow of our engines oil pump it caused the filter to bypass continuously which of course meant the oil never passed through the filter media.
Stick with the factory filter during the warranty period and for the couple of bucks more you dont have to worry.
