oil filter compatibility
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
lancet913
Car: 1996 240sx se
KA24DET @12psi
I have a 2005 altima 3.5 se. When ever I change the oil I always use the puralator filter for the 3.5. The filter for the 2.5 has a bigger capacity. Would it be safe to use the 2.5 filter on my 3.5? What I'm unsure of is if the filter relief valve would be the same pressures.
Purolator part # 2.5 L14610 3.5 L14612
lancet913
Car: 1996 240sx se
KA24DET @12psi
Ok, I did some more research and found out that they are interchangeable. The break down is:
Purolartor oil filter for the 2.5 #L14610 and \ 3.5 # L14612 Height 3.73" \ 2.86 O.D. 2.69" \ 2.69 PSI relief 11-17 \ 11-17 Thread size M20x1.5 \ M20x1.5
Return to “3rd Generation Altima Sedan (2002-2006)”
