dividedhighw »
https://forums.nicoclub.com/dividedhighw-u95262.html
Thu Oct 01, 2009 4:40 pm
I remember this wasn't as obvious as I had expected. Referring to the Owner's Manual, but otherwise from memory, this is what you do:
1. Enter the Maintenance option as shown on screen 6 of p.2-24 of the Owners Manual (from the screen shown, press bottom button until "MAINTENANCE" is highlighted, then press the top button to Enter into that mode).
2. Press the bottom button to highlight the option you wish to reset (you have 5 options as shown in the "MAINTENANCE:" section on p.2-26), then the top button to Enter that submenu.
3. Press the bottom button to highlight RESET, then the top button to select it.
4. Press the bottom button to Reset, then the top to Set (which I think is like a verification that you REALLY want to Reset).
That should do it. Follow the screen prompts to back out, or access another option similarly.
HTH.
