The design just needs to have the design of the base mounting tabs to be modified for RB applications. Should be real easy.. I wonder if they'd make a production run if there's strong enough interest.fast_s14 wrote:ka filter tree will not bolt up to the rb block. I thought about this aswell so i could get rid of the stock oil cooler on the rb25.
So far it's a KA only, but it looks like the CAD design could be modified for RB applications. I just like to have options and it looks pretty.Coolwhip wrote:I figured you guys would like the spin on type and run -AN fittings from directly off the block.
That way you don't have bolts or gaskets, just a standard o-ring to deal with.
The block adapters for relocating the filter even have the ports for 1/8 sensors.
I'll see about adding that to the site, and for the mentioned bolt on pieces, they can be made if thats the general consenus of what is wanted
