sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Thu Aug 21, 2008 5:36 pm
alright, i've been making ALOT of threads lately, and i apologize if i make them alot and seem not to search, but i do.
But i did finish the wiring. Got the injector resistor, the ignitor (Q45) and the MAF and Knock sensor all wired up. If it works the first time, i'll post a write-up of the Q45 ignitor. But you might have read about my Oil Pressure Gauge problem. I decided to give up on the idea of replacing the stock sending unit switch thing, and just go with an oil filter adapter. does anybody know what size i should get? Im ordering from Glowshift Direct, and they have 18mm, 20mm, 22mm, and 3/4-unf 16? Im thinking the 18 or 20 is right but not exacty sure which one. this is the last question i have for now, unless my motor doesn't crank and i can't figure it out
Thanks everybody, i am in debt to all who have helped me through my swap, and wiring and everything so far.
