oil filter adapter plate?
rb24t
Car: not so pretty but not so slow
my freind was going to give me a oil filter adapter plate to run a oil pressure sending unit for my gauge and the adapter plate has a 3/4-16 unf fitting will this work on my sr20det engine?
rb24t
? anyone?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
What kind of oil pressure sending unit are you getting? The Autometer sending unit that I got I believe was 3/4 and threaded right into one of the ports on the oil relocation plate.
rb24t
im refering to the sanwach plate, the fitting that holds it on the block?
positron1
Should work.
rb24t
im talking about what holds the adapter plate to the block, the bolt that goes into the big whol in the middle of the adapter plate that holds it to where the oil filter screws on.
onosqv
Car: '92 240sx Vert
3/4 16 is the correct thread/pitch for sr's & ka's.
Since you didn't specify what car that oil filter sandwich came from, the only thing you'd have to figure out is if the o-ring is the right size.
really tho, all you had to do was search - this question has been answered several times on here, & on the first page result when you search for it on google...
"oil filter thread pitch sr20det 3/4 16" search result
