oil filler cap???
wdebow
Car: 2012 Infiniti M37 Base
put a fancy cast alloy filler cap in wifes m37. Next day, engine fragged on interstate.
Full of fresh oil, coolant full, no overheating, no modifications
Is there any way that oil filler cap could have caused the engine faiure.???? (116000 on engine)
Not at all, unless it came apart and chunks wound up in the engine.
That's not a lot of miles for an engine failure. Timing chains don't usually fail that early - Would need more info to know what happened.
Is engine seized?
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
wdebow wrote:
Sat Oct 10, 2020 8:43 pm
I changed mine to a fancy anodized one and ran it for thousands of miles - no problem. Unless there were bits falling off on the inside, I don't see how that could be the problem. Have you taken the cap off to inspect it?
wdebow
I took the cap off, no signs of damage, been terrified to reinstall it on new (used) motor.
