oil feedline fitting
Sideways s12
Car: 84 turbo s12
Hey guys I just bought a braided oil feedline and the fitting that goes in the block doesn't fit its slightly to large. I need to know if anybody knows the size and thread pitch of the fitting that goes in to the block so i can replace the fitiing on the end of the hose...thx
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
i bought a banjo fitting adaotor and i think its 7/16 x 24 but dont hold me to that. measure it with some calipers and then use a thread pitch gauge to check the threads of the stock oil feed line
float_6969
That part that goes into the block is NPT. The threads in the block are BPT. You need to get a BPT to NPT adapter.
Sideways s12
Car: 84 turbo s12
so then the piece I have is right? and where can I find that adapter?
float_6969
Online. I've never found any BPT fittings locally.
themadscientist
Remove that fitting. The hole in the block is the correct size to accept the line directly. ;)
RS12Turbo
Sideways s12 wrote:so then the piece I have is right? and where can I find that adapter?
I got my block adapter from Summit. I think I still have the package it came in so I can look for the size, if needed.
Sideways s12
Car: 84 turbo s12
themadscientist wrote:Remove that fitting. The hole in the block is the correct size to accept the line directly. ;)
lol if I remove the fitting then there's nuthin on the end of the line
Sideways s12
Car: 84 turbo s12
hey Keith I tried to pm you on cs12 cn you empty your pm box I got a ca question for you....
RS12Turbo
Sideways s12 wrote:hey Keith I tried to pm you on cs12 cn you empty your pm box I got a ca question for you....
Sorry...deleted down to 43%.....should be good now. :biggrin:
themadscientist
No, the elbow fitting that is screwed into the block that the OE hard line threads into, remove that.
