iliketocrash »
https://forums.nicoclub.com/iliketocrash-u7672.html
Tue Jan 16, 2007 10:22 am
So i've searched the CA forums because i wanted to know what size fitting i'd need to mate up to the oil restrictor block on the block.. i came up with two diff measurements and something about the stock oil restrictor/fitting on the block being changed later in 1992 because the old one cause turbo starvation or something. anyway...
i've got a turbonetics t3/t4 and i was wondering if i should mate it to the stock oil restrictor on the block or take that out, tap the hole and buy a brand new and larger restrictor? Also, what diameter ss braided line should i buy? I've found all different sized lines and two different diamter restrictors but no answer on what i should use on my particular application. I've spent a lot of money on my parts and i don't have any left to replace anything if i break it. oh yeah. and if i should use the stock oil restrictor then what fitting do i need to screw into it, for sure?
on a side note. i think my turbo has a small in line oil filter built in or something. It's a brass femail fitting threaded in the top of the turbo and in the bottom of the fitting there is a small silver metal cube. kinda looks like its made from an uber fine mesh. anyone have any experience with these?
