pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Wed Jun 01, 2005 3:45 pm
on the oil restrictor the nut is 14mm while on the turbo side it is a 12mm, Don't use a regular 12mm or 14mm wrench you will strip the nuts, use a wrench which have a small opening to get it through the line, it is 80% close wrench, it is made for such lines.
If it is still won't come out, use a tourch and heat it up, but don't tourch the **** out of it and don't apply heat for a long period of time.
PULSAR GTRRafi
