oil feed question
turbo2nr
Car: 97 240sx (kouki)
quick question:
on the tee for the oil feed works?
or should the oil sending unnit and feed be switced?
thanks guys almost there~!
Kaleo55
Car: 95 240SX
turbo2nr wrote:quick question:on the tee for the oil feed works?
Yup... that's how I did it... Had a slight issue with the port on the block since it's BPT instead of NPT, just had to tap it out to 1/8 NPT for the fitting. The sender unit for some reason just fit right into the T
Note: motor is on a stand upside down.
nissanfanatic
Car: 1992 Nissan 240sx SE
That'll work. I would put the sender unit facing perpendicular to oil flow and have the oil feed running parallel to the outlet on the block. But this way will work...
WDRacing
That is the best illustration I've ever seen...LMAO. Simple and to the point, well done.
KATwo40
Car: 1993 240sx KA-T
Mine is as nissanfanatic described and I have no issues with it.
BTW, you'll read all over the internet that you need to run a 1/16" restrictor in the feed line...DON'T DO THAT!!!
I did it and it cost me a turbo. Now, I run a -10an drain and -4an supply, no problems at all.
Florida240sx
Mine goes:Oil pressure sender gauge ========== Block = = = Feed line to turbo
Beazle
Car: 1995 240sx
Kaleo55,
Do you have the JDMsport oil cooler/filter relocator they sell on ebay? If so how do you like it, does it fit well?
turbo2nr
thanks you guys done and done! woot! now on to mounting the fmic and pipes and im done!
then the hard part putting the 52lb injectors/top feed/ and tuning the e-manage....
Jung918
Car: 240sx
If you look to the right of the stock oil pressure unit, there is a hole with a plug in it. I plan on using a 1/8 npt to tap it and using a 90 elbow there.
Craving4Boost
Car: 91 240sx fastback
KATwo40 wrote:Mine is as nissanfanatic described and I have no issues with it.
I thought restrictions are suppose to be 1/8"?
