oil feed line
achilles0t
where do i run the oil feed line from. i know where the return line goes. also do i have to weld a new bung onto the intake manifold for my autometer water temp sensor or can i use an existing bung.
95_240sx
Car: My baby (car)
Oile feed FROM the stock sending unit for the oil pressure (right next to the oil filter towards the front of the engine.
Return, just weld a threaded bung into the oilpan and let oil pressure do the rest.
Rick
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
just pull the stock sensor off (there are 2 make sure you get the one for the dash gauge not the ECU) and stick the new sensor into the hole.
the Oil feed gets T'd off the pressure sender, it's a little round sensor about the diameter of a 50cent coin to the right of the oil filter (if I remember correctly). It's just a 1/8npt fitting that you can unscrew and stick the T in there, then put the pressure sender on one side and the oil feed line on the other.
piratepete
Are you sure it's npt? I was under the impression it was 1/8 bspt.
achilles0t
where in that series do most people put their oil cooler. somewhere on the return line or somwhere else
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
On mine, the turbo has it's own system (feeds from the oil pressure switch to the turbo back to the oil pan). I think most would agree that this is ideal.
The Oil Cooler came with a piece that mounted to the filter location and had an inlet and outlet. It also comes with a bracket to mount the filter elsewhere in the engine bay that also had an inlet and outlet. It's that simple. There are other types that use a "sandwich" type adapter (I believe it's called) that leaves the filter in its current location, but incorporates the inlet and outlet in between the filter and block.
QUICKFLOW240
Car: racing, cars, chicks, racing cars, racing chicks
so is it npt or 1/8bspt?
Movingviolation240
you know, now that you meniton that I had to run a 1/8npt into it to 'clean it out' so it would take my T, so I might be wrong on that one. But I did use the NPT fittings on the last 2 I did, but like I said I had to chase the threads both times to make it work. But then several people I know havn't had to and they also used NPT.
Anybody else want to comment that paid more attention than I did? hehe
erich
The oil sending unit is a friggin' tapered 1/8bspt.
I removed the other plug on the riser and ran a 1/8npt tap through it for my oil feed. Left he stock pressure sending unit undisturbed.
silviaNE
Car: cars what else?
it is 1/8 BSPTThrew me off the first time i did it to. Same thing on hondas to.
Sil-080
Car: Drifting...hahahaa
can someone show me some pictures of their oil feed parts?!
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Go to http://www.jgstools.com/turbo...look for "Turbo Accessories", then "T3/T4 Oil lines"...
Later - Brian
