Oil Feed Line Pics
JJ240
Car: 95 white 240
Heres some pics of a turbo oil feed line setup coming off the oil check valve. There were some questions about it awhile ago and I took the opportunity to take pictures while my engine was torn apart so it is easy to see. The fittings are 1/8th inch. And if you cant tell the pics are of the passenger side of the block. The oil filter mount is the large thing next to the check valve and the T off.
JJ240
Car: 95 white 240
and
JJ240
Car: 95 white 240
i dont know if this is working right. anyone know a better way to put pictures up? i have 4 to post
Structure240sx
its working for me
JJ240
Car: 95 white 240
ok great, ill finish then
JJ240
Car: 95 white 240
And be sure not to overtighten it. just use plumbers teflon tape onthe threads and maybe silicone sealant rather than tightening too much. Its easy to crack the block.
Structure240sx
where do u get the T fitting for the feed line? im goin to be peicing together my own kit after the internals are done. im getting mostly everything through my unlces machine shop. they just started selling turbos and obviously deal forged internals from JE, ross, crower, lunati im in heaven. anyway they will be able to get me whatever i need but jsut wondering where you get that fitting.
JJ240
Car: 95 white 240
I got it from ace hardware, but the two male to male fittings i got to attatch it to the engine and the feed line were different on each side so they wouldnt work if i was actually installing this. be careful what thread type you get on them. I just bought the stuff so i could take the pics and hopefully help some people. Im not turboing this engine
#1 Stunna
JJ240 - The first picture doesn't seem to be working.
Ivan
huguetpj
Car: 93 KAT Coupe
that's the same T y used for the install of my fuel press sensor
