I'm turbocharging the 9:1 compression NA engine. The question I have is where do I get oil pressure for the turbo oil feed line? Is there an already existing port on the block in the same place it would be on a turbo block or do I need to go somewhere else for pressure? Someone suggested some kind of sandwich oil filter thing that uses the oil filter port as a feed line... This seems like it could work but I have no idea how those things work or where to buy them.... I'm sure someone has run across this issue before... ANY OTHER SUGGESTIONS ON THE SWAP PLEASE FEEL FREE!!
