180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jul 29, 2006 10:40 pm
Check to make sure you weren't leaking oil at the oil feed of the turbo. That'll be the place to look for the source of the oil spray. Only place I can think of where the oil would be subject to high enough pressure to make a spray everywhere. To check out the turbo, check out the housings for the turbo. Oil in the housings = bad news. Turbos can fail in many other ways, like the blades blowing off, shaft play, etc. Not too many other parts you really need to check. Check the shaft and housings for the basics. That'll tell you usually if your turbo's toast or not.
