So basically, since your manifold is not seeing anymore vacuum, all of the blow-by is going through that rubber pipe coming from your valve cover. Also, since the car is turbocharged, it's seeing even more blowby than it would NA.FSM y0 wrote:This system returns blow-by gas to the intake collector. The positive crankcase ventilation (PCV) valve is provided to conduct crankcase blow-by gas to the intake manifold. During partial throttle operation of the engine, the intake manifold sucks the blow-by gas through the PCV valve. Normally, the capacity of the valve is sufficient to handle any blow0by and a small amount of ventilating air. The ventilating air is then drawn from the air duct, through the hose connecting air inlet tubes to the rocker cover, into the crankcase. Under full0throttle condition, the manifold vacuum is insuffiecient to draw the blow0by flow through the valve, and its flow goes through the hose connection in the reverse direction. On vehicles with an excessively high blow-by some of the flow will go through the hose connection to the intake collector under all conditions.
Did they even have a pcv valve? Why would they have one if it wouldn't work under boost anyway?WDRacing wrote:Thats why we run the valve cover vent into a seperate catch tank...I didn't even use a PCV valve on eithe of the Skylines I owned.
There is the PCV valve that connects to your intake manifold, and there is another PCV line that you see connected from the valve cover. The fsm has a good diagram of it. Section CE.virus77 wrote:The PCV line is hooked up before the turbo so it never sees boost, just vacuum.
when i performed my compression test on my 96 with the fuel pump fuse pulled. I forgot to tell my friend that was cranking the car to put his foot on the gas wot. so i did the test again later that night and got the same results with the throttle at wot, i belive holding the throttle at wot is for carburated engines only, becuase of the low engine rpm the iacv has the ability to supply enough air to the engine without restriction while the starter is turning over the motor. has anyone else had a simalar experiance?crzycav86 wrote:Don't forget to have throttle at WOT.
