oil drain flange kit
98240
Does anyone know the thread and bore for a t3 air research super 60?Or do you know what flange i would have to use for the -10an fittlng?I am getting this from anplumbing.com I looked in the sticky and found some part numbers but not all of them for what the guy had used. He mentoned that you would have to get the oil drain flange for your specific turbo. I looked on the site and couldnt find anything with a flange.
All help will be appreciated
Import_Ant
http://store.yahoo.com/cheaptu....html
if you need a return flange you can buy that one. It's tapped for 1/2" NPT.
alternatively they sell oil return flanges that aren't tapped, they're just a tube you slide a hose over and connect the return line to the bung on your oil pan.
I'm not 100% sure I understood your post but I hope that helps.
