oil drain backwards/ clocking turbo
wild_maxx
Car: 90 TT pearl yellow z32
well i know how to clock the compressor housing of my turbo but i want to be sure on how to clock the center section before i do it. problem is, oil drain is pointing striaght up and oil feed is straight down. now should i loosen the red circled bolts and do a 180* with the center section or any other way to do it? oil drain:oil feed:
C-Kwik
Yes, just clock the center section the way you stated. Then clock the compressor housing however you need.
wild_maxx
thats good to hear thanx alot. it wont mess with any bearing or anything right?
Structure240sx
the bearings are inside of the center cartirage. unbolting the housings only unbolt the housings. if you were to take them off you would jsut see the compressor and turbine wheels
Titan
wild_maxx wrote:thats good to hear thanx alot. it wont mess with any bearing or anything right?
Nope. There are no bearings present around the mating lips of the turbine housings.
If you are using the internal wastegate, here's a tip. When you finally clock the intake housing, make sure the wastegate actuator mounting location matches with the wastegate flap. Judging by your picture, it seems your wastegate will be external since I do not see the flap and hinge, however I can't see the other side of the turbo.
wild_maxx
great thanx alot guys. yes i am going to run an external WG.heres a progress pic:
Import_Ant
That's one handsome looking motor
D Money
Car: driving illegaly
r u keeping pwr steering?
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
very clean motor!
wild_maxx
D Money wrote:r u keeping pwr steering?
yes i am. this is a sohc so the PS is on the other side.
DRIFTEADOR
what turbo is that?
veilside180sx
T3/T04E 50 Trim .48/.63
wild_maxx
yep thanx to mr. veilside180sx
DRIFTEADOR
hmm... for some reason it looked huge when I first looked at it. probably cause i was comparing size against the tide container. I usually buy the big jug
