ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Fri Oct 31, 2014 7:03 am
You sure the tube is kinked? A common problem when the oil pan has been removed and put back on is that if you leave the dipstick in, it gets caught and causes the dip stick to not be able to be pulled out. Only way to fix this is to drop oil pan. You can technically try to do it engine in by dropping the front cross member and supporting the engine.
