dnasty88 »
https://forums.nicoclub.com/dnasty88-u103113.html
Fri Oct 31, 2008 11:47 am
just changed my car oil. checked the dipstick. it read halfway in the middle of the two dots with little less than half quart left in quart number 5. added more went up. ultimately i ended up filling it with all 5 quarts even though the manual says 4 7/8s. every time i check the dipstick i get a different reading. im parked in the same exact spot, which is flat. and havent moved or started the car. 3 outta 5 tries i get around the same which is about 1/8th inch below the top dot on the dipstick. other times above the top dot even into the bend of the dipstick. wtf?
