kapower06 wrote:Why are you scared to turn up the boost with out an oil cooler? how much horsepower do you have and whats your set-up? Just get an oil pressure gauge and use a good oil (Mobil 1) and a good filter (wix, k&n, puralator)
heat=wear, heat+oil=hot oil, hot oil can lead to sheared bearings and because motors are expensive and i have no money, i's not really all that scared, just making conversation, of course, you do have a point about the oil pressure, leaking fittings=low oil pressure=grenade!!...just one other quick question whilst on the subject, what's the thread pitch for the oil pressure dummy light sensor (that'd be the one in the block, below the oil filter), i'm getting a pressure gauge but would like to retain that light if at all possible, and thanks rico05
