koukiKA240 wrote:what made you give up? MarkEMark was able to pull it off.~Sam
There's nothing special about my setup...my setup cools all the oil in the engine, so the oil going to the turbo is cooled too technically, but it's not set up any special way just to get the oil cool for the turbo.
Also, eddiec..good luck with those fittings...you may have clearance issues/they may not work at all. If you look at the second pic I posted, my fittings are short 90 degree elbows, otherwise they (or the oil lines) would have run right into the motor mount/its mounting bracket. Especially with long, straight aeroquip fittings and inflexible stainless aeroquip hose, I don't know how much success you're going to have fitting it there...I'd use elbows if I were you.
I'm AMAZED how few people have oil coolers with their KA-Ts...it was the first thing on my list before I turbocharged anything...it just makes so much sense.
