480sx »
https://forums.nicoclub.com/480sx-u50548.html
Mon May 21, 2007 1:48 pm
If your trying to save some cash, id go with a DIY oil cooler. Basically, all you need to do is get an oil sandwich plate, and an oil relocation kit. You can get this stuff on ebay at the right price. I got a sweet CNC oil cooler sandwich plate from ebay, if you want the name of who i got it from PM me and ill let you know.
Run your lines from the sandwich plate that fits between your oil filter and your block to the relocation oil filter. You can mount the relocation plate wherever, but it might help to have it where its got a good source of air. Then get a huge oil filter, like one for a big block Chevy and that acts as your oil cooler. You can even get fancy and get these magnet things that stick to the side of the oil filter that have aluminum fins on them for additional cooling.
Also, an oil cooler, no mater what brand you get isnt going to just fall apart. There is almost no freaken way that one will burst. You can spend all the money in the world on an oil cooler, but its always going to be the lines that go bad on you. The weakest link in your oiling system with an oil cooler would be the lines, so dont cheap out on the lines.
