Oil cooler sandwich plate?
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
Where can I find one I'm going to be putting in an oil cooler, I found an eight row cooler out of a newer ford van at the junkyard. So I just need to know where to find one and such thanks!
ca20det
Car: 89 240sx 93 sentra
bought mine on ebay don't know if it is going to work as "advertised" , not yet installed..... pegasus sells one too but not sandwich plate...
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
http://store.240sxmotoring.com/groilcoadw.html
that will
most parts places have them all you have to do is ask.
Red93coupe
Yeah I can get them at my work for cheap (B&M) but all it says is fits most imports, so I didn't know if it would?
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
As long as it is 3/4-16 thread pitch it should work perfectly. Look for one with a built in thermostat.
RS12Turbo
Perma Cool.....I got mine from Summit
Red93coupe
What it be a huge deal if I didn't have a thermostat in it?
RS12Turbo
I've always heard there should be a t-stat.....but I've been using an oil cooler without an t-stat for 2+ years. I plan to get one, just haven't done so yet. I think there are a few others here don't use them as well
lostmenoggin
the t-stat only allows the oil to be cooled once it has reached a certain temperature (185*/195* IIRC) so it doesnt get overcooled, helps with warm ups, etc..
Nunook
questionwhen changing the oil DO u have to take off one of the lines in order to empty the oil cooler?
also when the t-stat opens, if there is air in the cooler wont that momentarily starve ur engine? or atleast drop the pressure?
bentvalves
Car: 89 Silvia K's
I can see a sandwich plate being an issue with the orientation of the inlet/outlet. Its going to point wherever it wants to when its tightened, and this could create routing issues.
Greg
bentvalves
Car: 89 Silvia K's
bump
Im after one of these but because of what I've mentioned above, I am unsure if I should go with a sandwich plate, or a filter relocation kit.
Greg
RS12Turbo
I've got a Perma Cool sandwich plate that I don't use, if you want it. It's almost brand new.....I only used it for one oil change, so it's only got like 2500-3000 miles on it. I bought a oil filter relocation kit so I could use one of the BIG 1 qt. filters.....otherwise I would still be using the sanwich plate. I have straight fittings for it, and 90 degree fittings.Let me know if interested, and I'll post up some pics of it
bentvalves
Car: 89 Silvia K's
sure post some pics if ya dont mind.
in any event, to the rest of you FOOLS my first question still stands.
Greg
RS12Turbo
I'll snap and get some pics up tonight.
What was the question...the orientation of the inlet/ outlet?
ca18detgabby
03 Infiniti G35
I too would be curious about pressure drops with a T-stat unit. I know with the trans cooler we installed on the Sprint, we had to add extra fluid to prevent pressure loss....(as the pressure releases into the empty space).
then again we did it inline and didnt have to add a plate.
bentvalves
Car: 89 Silvia K's
RS12Turbo wrote:I'll snap and get some pics up tonight.
yea, because they are threaded on and the inlet/outlet would basically end up wherever it wanted to be.
RS12Turbo
I'll show in my pics....but the part of the sandwich plate that has the in and out nipples on it swivels independently from the shaft that screw onto the block....so you can rotate it 360 degrees to where ever you want. I don't know if all sandwich plates are 2 pieces....but the one I have (Perma Cool) is.....
RS12Turbo
I just pulled out my old ca18et block out of storage to take pics with the spin-on sandwich plate on it. The block is physically identical to the ca18det block.......externally.
here is the back of the adaptor, with the o-ring, which is what sits against the block.
And the front of it, where the filter screws onto.....also in the pic is the screw on center section that holds the sandwich plate to the block, which allows you to swivel the unit 360 degrees. Also the little adaptor to match the thread on the block.
bentvalves
Car: 89 Silvia K's
What size NPT are those barbed fittings?
Greg
RS12Turbo
3/8 npt. The sandwich plate came with just the straight 3/8 npt barb fittings. I bought the 90 degree fittings and used the barb'd fittings with the 90's so it would bring the hoses out from the engine, and make the hose routing easier
bentvalves
Car: 89 Silvia K's
3/8 npt I believe thats a -10 an.
I'll check tommorow.
psilocyben
Car: 1992 240sx
AN Size - 2 -3 -4 -5 -6 -8 -10 -12 -16 Tube OD 1/8 3/16 1/4 5/16 3/8 1/2 5/8 3/4 1 Here is a good link
http://en.wikipedia.org/wiki/AN_thread
