oil cooler questions
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
i have all everything i need to install the cooler and have it work. Im using the following:
-10 AN Russell SS LinesGreddy Oil Filter Sandwich w/ ThermostatSummit Racing and Fragola FittingsB&M Oil Cooler (3.5x11x1.5) (HxWxThickness in inches)
How much oil should i pour in now? also, on a side note, should i run 10W-30 or 10W-40 Castrol GTX Anti Sludge?
Thanks.
Ca_Silvia
Like big diesel trucks, just fill the cooler till she's full. Plumb all the lines up and start her up!
EDIT: my oil cooler might add .2 of a liter of oil, if that.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah how about you get off yer duff and fill it to see how much it holds. Will be useful as hell when your next oil change comes around.
bentvalves
Car: 89 Silvia K's
oil dipsticks are also useful as hell.
sjbsuperman1425
CA18DET
head is off car, oil cooler is in X-Mas wrapping, and I dont have oil. I just figured asking couldn't hurt while i was waiting for the snow to clear and to get the car back home, but I guess it did. I thought I'd ask, but i'll never ask again unless i REALLY need it. Sorry to cause you guys an inconvience.
Modified by sjbsuperman1425 at 4:06 PM 12/10/2009
float_6969
WTF? Where did that come from?
Never run anything less than 10-40 in a turbo motor.
You'll just have to fill it and see how much it takes. If I had to guess, you're an extra 1/4 of a quart.
sjbsuperman1425
CA18DET
thanks Ryan.
float_6969
No prob.
mbmbmb23
Most of the extra oil will be held in the lines therefore the length of your lines is what mostly determines how much more oil you can hold so fill up the capped lines with water and pour them into a measuring cup.
zombieslider
i would connect the lines to the cooler and then do that but yes this would be the most accurate way to do it
mbmbmb23 wrote:Most of the extra oil will be held in the lines therefore the length of your lines is what mostly determines how much more oil you can hold so fill up the capped lines with water and pour them into a measuring cup.
mbmbmb23
zombieslider wrote:i would connect the lines to the cooler and then do that but yes this would be the most accurate way to do it
Well...yes...but he said his cooler is giftwrapped and under the Xmas tree...so I figured maybe his lines were available to tinker with for a preliminary measurement.
sjbsuperman1425
CA18DET
nope, the whole setup is gift-wrapped
i think it would be wise for me to unwrap them (X-Mas morning of course) then later connect everything, fill the lines and cooler with oil, then measure the amount of oil
rico05
Car: 1992 RMS13 w/ CA18DET
Did you pay attention in high school geometry class? http://www.mathsteacher.com.au...r.htm
Consider the lines as a cylinder. Then, fill the cooler with water and measure how much it took to fill. Add to the volume of the lines, and viola!
Remember, math is fundamental!
sjbsuperman1425
CA18DET
i hated Geometry. lol
DALAZ_68
Car: 90' 240sx CA18det
which kit did you get btw...im thinking of saying f it and just buying a kit that works on SR's...600, but i just dont have time to put things together...
sjbsuperman1425
CA18DET
i didn't buy a kit i just bought all the materials from Summit Racing. I'd buy an Isis Cooler Kit for an SR if I were you though. I heard they were decent and are $300. i've spent about $300 on my kit with a Greddy thermostatic oil sandwich though.
BQ.05.TD
Car: ca pulsar
ks13 wrote:oil dipsticks are also useful as hell.
when its on. fill up with oil start for 2-3min then turn of and check dip stick and fill to line. you should do that after every oil change any way to fill oil filter with oil
