Oil cooler question
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I'm thinking that I want to install an oil cooler but Im not sure on the routing. I was going to pull one off an Fc,rx7, but I do not want to get an oil filter relocation kit...to pricey...Instead I was going to get an oil sandwich for my turbo feed... It has two more outlets on it so i figure I can run one for the oil cooler...But where does it go after that?I was thinking I could route it back to the oil pan...But then Id have to tap another hole.Or I could put the cooler in between the filter and the turbo, and run the same drain into the pan.Could either of these cause a problem?
KATwo40
Car: 1993 240sx KA-T
The Mocal sandwich adapter has an oil out and oil in. You just run one line to the cooler, then another back to the adapter.
martins_240sx
Oh I see....Those ebay ones dont have that do they?where can I get a mocal?
KATwo40
