I did not have enough room for my socket , I ended up using a ratcheting wrench, also I pressure washed the entire area around that cooler, you do not want grease grime and road dirt getting into that area while you are replacing the gasket , remember this is your oiling system !! Be very carful not to get anything in there. I also used brake cleaner to clean the inside of the mating surfaces, I also gave the gaskets a light coat of oil, it seams to be about 50-50 in the video's , whether the person doing it coats the gaskets, but the way I look at it we always coat the oil filter gasket when installing a new one , so I gave a light coat to mine. I positioned the cooler from under my QX4, coming in from the rear , then once the bolt is started I went to the front of my vehicle to access turning the bolt to tighten with my ratcheting wrench. Fired it up took a trip around the block and NO LEAKS !!!
