Chris:
ACEA is a european standardization system for oils.
ACEA A3 is the highest.A1,A2, A5 are also more stringets than out API SL specs.
Nearly all oils sold in USA meet API SL nowadays ( even tho many still carry SJ label.
ACEA is a bit more stringent in the areas of deposit control, volatilty, stability and HT/HS.
With A3 being the toughest, requiring ( among other things) a HT/HS of at least 3.6 at 150 C.
The Porsche oils specs, BMW oil specs and MB specs are built around ACEA A1 and ACEA A3 depending on teh model.
There are also B rating and E ratings for diesle and economy specs.
But its simplest for me to just look at the ACEA A..
Fred...
