crazyandevil05 »
https://forums.nicoclub.com/crazyandevil05-u69665.html
Mon Sep 07, 2009 6:42 am
ok, in the kit has everything i used. there is an adapter that bolts into the old oil filter location. it comes with a bunch of adapters to fit whatever size needed. you just screw that on.on said adapter, there are 2 holes, with fittings for the rubber holes, marked "IN" and "OUT".you use the hose in the kit (it shows in the included manual to go from in or out nozels to cooler and filter, cant remember off the top of my head (as in (OUT FILTER COOLER IN) , cut the hose to length depending on where you need to put the filter.there is a place to screw in the filter (with adapters and in and outs also) and plumb it up.then the other hose to the cooler. there was plenty of hose and clamps in there, i think 7 feet?great deal, and works just as it should. its wicked simple, dont even have to do a complete oil change, just replace what was in the filter + spillage. Wicked product. (even though it may seem like it, i dont work for summit, but everything i've gotten from them has been great!oh, but keep in mind it isnt regulated with a thermostat, so in cold weather may take longer to warm up.
