Hey guys, well Im almost done assembling my KA-T Project, and have everything done out pretty much here is the deal. I have this Oil cooler http://www.jegs.com/webapp/wcs...18267 My question is, can I run my oil feed line in conjunction with one of the lines going to the oil cooler. Or should I run it off my oil pressure sensor. But my oil pressure sensor is slightly modded, because I have a steel braided line running form the oil pressure sensor tap to my fire wall, and then I have my oil pres gauge and my stock one coming off of that. Kind of a fail safe, because I heard that when ppl sandwich them down there they break off heh. Anyways I can also run my oil feed line of that one? Which seems like the better choice?
BTW the search button and the sticky has helped me out tremendously in my little project thank you
