Easy240 »
https://forums.nicoclub.com/easy240-u208215.html
Tue Mar 05, 2013 6:16 pm
The block had been decked/honed/bored os, the crank was ground for .25 undersize bearings and polished, balanced with the rods/pistons. The Machinist sold me these bearings when I picked up the crank and block. I did use platic gauge to check clearance on main bearings, but not on the rods. I have manley h beam rods with ARP bolts, but no arp main studs.
The oil pump was also rebuilt. Oil was changed 5 times during the 800 miles with 5w-30 castrol gtx (was cheap) and Bosch oil filters.
It DID run hot a couple times do to air in the system, but it never over heated.
Been really busy lately, but I had a chance to measure this rod bearing and it is indeed the wrong size! Lesson learned.
The machinist told me to order undersize 0.25, but changed his mind and said he would get them. This guy is a master, so I trusted him. Too much I guess!
Factory specs from FSM state undersize 0.25mm thickness should be 0.0769 - 0.0772 in. Mine is 0.0699 in.!
I remember why I didn't plastic gauge the rods, I kept messing up the line taking off the rod cap! Any good advice on doing this?
Thanks again everyone!
