nissan2.4 »
https://forums.nicoclub.com/nissan2-4-u75605.html
Sat Sep 08, 2007 9:21 pm
I see that no one has replied, but i also rebuilt my kA. Replaced everything you did rings, pistons, etc. And it doesn't seem normal for ur Ka to be consuming that much oil. When my engine hit 1k miles it had consumed about 1 quart. The more miles i got on it, the less oil it comsumed. I have about 25k on my motor now and i hardly consumes any oil. If you installed the wrong size rings, that could be the problem. Cuz if they are the wrong size, ur ring gap is wrong and that would cause ur abnormal oil consumption. Also when you installed ur rings, did set one ring gap at 12 o clock postion, another one at 3, and another one at 6 or 9, cuz that could be another problem. Also how many miles do you get on ur oil before it is black, cuz if you dont get too many, that is caused by excessive blow by which is caused bad rings or ur case incorrect ring size or rings not installed properly.
