Postby
flizsr45 »
https://forums.nicoclub.com/flizsr45-u56340.htmlFri Mar 09, 2007 4:15 pm
My 03 is monitored for oil consumption. What has been if the vehicle is consuming to much oil? Does the engine get replaced, or is there some other fix? Thanks.
Postby
szh »
https://forums.nicoclub.com/szh-u149.htmlSun Mar 11, 2007 3:43 am
Yup.
Apparently, the threshold is 1 qt used below 1000 miles (and, even then, you may have to force the issue, although they may have gotten better about this).
Which I consider very high use, but that is the criterion used by Infiniti to replace the engine on those problems.
Postby
ProvidenceLeaf »
https://forums.nicoclub.com/providenceleaf-u51848.htmlSun Mar 11, 2007 5:20 am
So I am going back in the next couple of days for my first 1000 miles follow up since they decided to monitor the oil consumption. What happens if they discover more than a quart is burned off? Do they try this test again? Will I have to pay for another oil change? thanks for any help with this...
