Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Tue Nov 24, 2009 9:15 am
Ok. I know at least a few of the 05+ 6MT Gs have had oil consumption. With some, it might be extreme. With others, it might be just a minor annoyance.
Here's what I'd like you to do.
Check-in - I have a 2005 G35 Coupe. It consumed enough oil to be eligible for the TSB and revised engine.
How much oil does your G35 consume - This varies a lot. If the dealership does an oil change, I see little to no consumption or none until after 2000 miles. My past OCT showed no consumption after 3000 miles. Previous tests have shown 1/2-3/4 low from the H mark.
When I use any Mobil 1 product, the car drinks oil like tainted Kool-aid. Not sure exactly how much, but probably 1.5 qts per oil change.
Estimate your city/highway ratio and what your highway cruise speed is.- My current ratio is 5/95 and I cruise at 80 when possible.
Once I get enough responses, I have an idea that might place a cause on this dumb issue once and for all.
