Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Mon Aug 19, 2013 7:29 am
Can you try a thinner oil, maybe 10W-40 and see if the oil consumption decreases? 20W-50 is not necessary. You would likely be fine with a 5W-30 even - the engine's cooling system will keep temperatures within specifications. If you had an air-cooled engine, I can understand the thicker oil.
