Jacko3 wrote:I don't know why you want to switch to 0-30 grade of oil. 0-30 will work--it only means that the oil does not have any cold start characteristics, which could possibly wear down your engine over time when starting in even a remotely cold area. t of the oil means that the oil will behave or flow the same way in a temperate area (5W) as it would in a warm area ()-30). 0-30 grade is only good for warm areas---this means only summer like temperature use. So think about this before buying the oil.
Jacko,
This information is completely opposite of the truth. The Xw in 0w, 5w,10w refers to the pour point of the oil. This means that the oil can be much colder and still flow easily.
Usually, you will see 0w and 5w on Fully Synthetic and Synthetic blends. This is because conventional oil has wax in it and requires significant modification and additives to be able to both pour at a low temperature and have it's specific SAE viscousity (the second number in the oil grade).
One of the biggest issues I SEE, is oil shear or viscousity degradation with use in conventional oils. You're asking mineral oil to flow easily at very low temperatures and to provide film strength at high pressure, high temperature, high stress points.
My general BELIEF is that a conventional oil with a low pour point is more likely to shear and suffer viscousity degradation than the same multi-weight synthetic. The reason why is that synthetics do no contain waxes and flow easily in high or low heat situations. As such, they are designed to have a wide working working temperature range.
