texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sat Oct 02, 2004 2:14 pm
You have varnish. Not a good thing to have. 3 approaches to remove it. 1) Use the STP engine flush per instructions. 2) use Seafoam or similar volatile solvents (all contain xcasv-ether, alcohol, xylene) per directions, or 3) use one of the new 'high mileage-clean-up oils.
Caused by running oil too long between changes, cheap gas, oil not formulated to handle gasahol.
