DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Nov 01, 2002 6:58 pm
That's pretty cheap. But it gets closer when you add the 6th qt of oil, as mentioned, and more expensive if you also provide them with the factory filter. Then add the trust you've developed with the mechanic who knows your car, versus some kid who's going to opt NOT to replace the plastic undercover because he either forgets or because its too much of a hassle.
