Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Nov 14, 2002 9:23 am
Cleaners are good to clean the varnishes that oil may leave. Look inside the oil filler port with a flash light. Do you see any baked on crud on the metal baffel plates.....amber, brown, black,,,,,if all you find is pure shiny metal you don'y need anything!
Unfortunately almost nothing will remove certain types amber or heat broken down oil byproducts......most of the things sold will not do harm if added a few hours before a drain as long as you don't add more than a quart and don't rev the engine above 3,000 rpm......this does not apply to sludged engines where chunks may be broken off the sludge and block the oil pick up.
Just wait till it gets 240,000 miles on it,.... it will start to get dirty at 500-1,000 miles as the ring gap is not narrowed till it warms up after each cold crank.
Still won't burn any noticeable oil in 3k but the cumbustion soot from the cylinder walls get into the oil faster.
