Post by Pineapple » https://forums.nicoclub.com/pineapple-u150410.html Thu Dec 31, 2009 7:02 pm
Post by smilygo » https://forums.nicoclub.com/smilygo-u145302.html Mon Jan 04, 2010 11:25 am
Post by nafddur » https://forums.nicoclub.com/nafddur-u126461.html Mon Jan 04, 2010 7:16 pm
Agree, it's super easy. I removed the panel covering the filter the first few times I changed the oil on my 04 SE, but then realized that just pulling the panel up from the bottom (and not removing it) was all that was needed to access the filter. It's even easier to get at the filter if you take the front passenger side wheel off - something I do every oil change since I always rotate my tires when I change my oil (twice a year).smilygo wrote:You crawl under the car and remove the plastic panels held by platic snaps. You see the oil filter right there.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
