oil change
MNVERT
Car: s13
what oil do you guys use? i just recently got a oil change and coolant flush at jiffy lube using penzoil high mileage oil, prior to that i had mobil one but wasnt sure which exact mobile 1 it was. but ne ways the high mileage engine make the car feels slower anyone else had this problem? the mobile one i think was definitely better
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
I don't know many people who like to use penzoil...
Mobil 1 has been my choice for performance engines for the last several years.
For initial break-in (0-500 miles), I use the cheapest stuff I can find. Then I run cheap synthetic blend (500-2000 miles). After that, it's usually full-synthetic Mobil 1.
zack240man
Car: s13 hatch ka24det & s13 coupe sr20det
oil shoudnt affect your engine to the point of noticing. even some of your performance oils are only noticable on the dyno and its usually only a 2 hp increase. check around your engine bay to make sure no sensors or plugs are undone. the guys changing your oil could of had unhooked one
biggie
Just always stuck with Valvoline regular oil. Still use it on my coupe (180k+ miles).
Put in Mobil 1 5000 reg oil in my Versa last time, didn't notice any difference or anything, no complaints.
Haven't had a boosted engine yet, when I do it will be Mobil 1 full syn.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
biggie wrote:Just always stuck with Valvoline regular oil. Still use it on my coupe (180k+ miles).
MNVERT
Car: s13
yea penzoil sucks i seriously notice a difference. i think the high mileage oil is a bit thicker correct me if im wrong. is it okay to use full synthetic in a 100k mile ka??
Florida240sx
Full synthetic on an older car may cause your seals start to leak. did a project on motor oils. Valvoline was best penzoil was the worst mobil was the 2nd best.penzoil started to pop like bacon grease
BOOMSHAKALAKA
I used to use Castrol. Now I use Mobil 1. I've heard a lot of good things about Royal Purple so I may switch over to that later on.
wmdavis007
Car: 1992 240SX Convertible
1997 Jeep Wrangler Sahara 4.0L
I used to use Mobil 1 but I switched to Royal Purple full synthetic...not only the engine oil but I use it in my transmission, rear diff. and use Purple Ice in my engine coolant. It's a little high but it's good stuff.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
i use royal purple on my vert and frontier, both being KA, and it works fine
the vert has 150k miles and the frontier has 80k
