Oil Change question...
LuckyLuke
Car: G37s - HKS Exhaust - R2C Performance Intake
Will infiniti void my warranty if I bring my G to Nissan dealership to do oil change? There is no infiniti dealer in my city, only Nissan.. the closest one is like 30-40 mins away..
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
no, they don't care if you get it done at Ford as long as you keep receipts. Actually, you can diy as long as you keep receipts for oil and filters.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Yea what Rich said.Just dont go to jiffy lube or [email protected] car will refuse to start and it will angrily deply the airbag in your face.
LuckyLuke
SVTCOBRA wrote:Grrrrrr....
Man, angry dog!
atn_chargers
Will Infiniti charge you more for an oil change? I talked to one of the mechanics at my Inifiniti dealership. I told him my car has 35k miles on it already. He says I should get the 30k mile check up. Which costs about $700
pfarmer
Car: 2008 GXS with technology package
atn_chargers wrote:Will Infiniti charge you more for an oil change? I talked to one of the mechanics at my Inifiniti dealership. I told him my car has 35k miles on it already. He says I should get the 30k mile check up. Which costs about $700
From what I have seen nearly everything has been quoted to me at double the Nissan price.
Perry
LuckyLuke
my G is being violated by a bunch of nissan techs.. they r all standing under my car checking out the exhaust.. what do i do? should i call the cop?
Poyzinous
LuckyLuke wrote:they are all standing under my car checking out the exhaust.
You should tell them to take a video, it'll impress longer
pfarmer wrote:From what I have seen nearly everything has been quoted to me at double the Nissan price.
They must not like you perry. I find my dealer a little on the high side compared to some others, but I take care of Nico guys, as does Steve
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
my 30k check up turned into $1200...
here is what i got done
http://forums.g35club.org/zerothread?id=410652
SVTCOBRA
kmckis1029 wrote:my 30k check up turned into $1200...
At first I was like But, you got a lot of other stuff done....still....
pfarmer
Poyzinous wrote: You should tell them to take a video, it'll impress longer
So far the Nissan dealer has quoted me a 15k service and has done an oil change with Ester oil at roughly 1/2 the price quoted by Infiniti.
Perry
LuckyLuke
Now, I have annoying Oil Change reminder pop up.. How do i turn it off?
Poyzinous
in the VIS, go to maintenance, click into your interval selections, reset.
LuckyLuke
Actually, not the reminder LCD.. but maintenance warning between the Speed and RPM odometer... do I have to go to shop to do that?
Poyzinous
No. Those two buttons on your instrument cluster, use them to nagivate through the settings and click reset on the intervals.
danstirling
Car: 2007 G35S Sedan
I had the same problem - and the dealer didn't know how to fix it either! Fixed it once and forgot, but I was able to remove the warnings today with the following method:
Start the engine. Go ahead and clear the warnings by hitting the top button on the console to the right of the display (Trip computer switch A - consult the manual if you don't understand to which buttons I am referring: page 2-27 in the 2007 G35 manual.) Continue to press that button until you get to the maintenance part, then press the lower button (Trip computer switch B) to navigate within that section. You should be able to easily reset the mileage to clear the warnings with a little trial & error at this point. Note that the engine must be running, although it doesn't matter what gear you're in (but it will not let you make changes if the car is moving.)
