oil change question
ahmed_wasim
Car: 95 Q45
I dropped my car (02 Q45 with 115k miles) for front suspension change. The mechanic also changed the oil and put synthetic oil with an aftermarket filter. I normally don't use synthetic oil.
Should I take it to Nissan tomorrow to put factory filter and regular oil or is it ok to drive until next oil change
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Should be fine. No reason to be afraid of syn. Biggest question for me would be which brand of filter they used. I'd be fine with some aftermarket brands, but others I'd want to replace. Even if it's an undesirable filter brand, the car is fine to drive, you'll just get better results if you change it.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I'd be more concerned with the brand of the filter and whether he used the OEM or other copper crush washer.
You can change the oil sooner which is never a bad thing.
ahmed_wasim
Car: 95 Q45
I don't know what kind of filter he used. I'll have an oil change by Nissan in a week or so
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You can look at the filter and determine what it is or just ask your mechanic about both.
qship96
Car: 1996 Infiniti Q45
ahmed_wasim wrote:I don't know what kind of filter he used. I'll have an oil change by Nissan in a week or so
Why would you drain out fresh synthetic oil ???? Run the oil at least 90 days, or whatever your normal interval is.....certainly the synthetic oil in there now is superior to the bulk cheap conventional oil the dealer uses. Any oil filter,even a cheap Fram, is fine for a 90 day interval.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I only run synthetic oil.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Just stick with conventional oil...the snythetic really won't benefit the Q45 much and you'll be wasting money becuase the F50 burns oil like a 3 alarm fire.
2005Q45er
Car: 2005 INFINITI Q45
i think the car will be fine, they will last a long time!
